cyxlqcyz Posted November 24, 2011 Share Posted November 24, 2011 I always have an error like this: 2011-11-23 20:37:09 Failed writing file: [The requested lookup key was not found in any active activation context] After that, the task stops with red cross in front. It will report that error again if you restart the task immediately. What I found is to do a manual hash check and then restart it. The task will download for a while and get that error again. It sometimes works good for 3~4 GB data. However, in most cases, it has error less less than 1 GB. System: windows 7 64 bit professional bitcomet: 64bit 1.30 stable BTW, I have RAID0 in my computer. Link to comment Share on other sites More sharing options...
Vasy Posted November 24, 2011 Share Posted November 24, 2011 Have you installed a new version of Internet Explorer lately? All references I find for this error are IE related. And BitComet has an integrated version of IE. Link to comment Share on other sites More sharing options...
kluelos Posted November 24, 2011 Share Posted November 24, 2011 I have also encountered this error, but only in the last 6-8 months or so. It happens to some particular torrent, can only be cured by deleting the download and starting over, and often recurs when it does happen, at which point I usually give up. Link to comment Share on other sites More sharing options...
Kaicanoe Posted May 5, 2014 Share Posted May 5, 2014 The fatal x message "the requested lookup key was not found" coninues on. There must be some solution to this as I was using version 1.37 64bit with windows 8.1, downloading up to April 16, 2014, and then....the Red X. Any ideas, any one? Link to comment Share on other sites More sharing options...
