0.75....needs to close
I reinstalled my computer last night and tried to run the version of 0.7 and 0.75 and problems happened as follow:
Problem on 0.7 - I cannot see the status (name of torrent, speed of download and upload & etc.)
So, I removed the 0.7 and installed the 0.75
Problem on 0.75 - The following message appeared almost every 10 minutes:
"0.75 BitComet.exe has encounted a problem and needs to close, we are sorry for the inconvenience. Then the programe closed.
Please help me to fix the above problems.
Thanks
0.70 is the last stable version. Problems with later versions are pretty normal, so they’re not recommended, use at your own risk, etc.
“Cannot see the status” is really unclear. Can you describe more accurately what you’re seeing/expecting to see/not seeing? What did you try, what did you expect, what happened instead.
“Cannot see the Staus”
When I was downloading, I cannot see the name of torrent, size of the file, download/upload speed & etc.
I recommend you reinstall version .70, and if it still has this problem, then please attach a screenshot.
I encounter the same problem after installation of the newer version of 0.7 and later. I cannot see the menu bar, torrent file name, speed, etc. Afterall, nothing I can see. I can only see the number of jobs on-going. This problem is serious when you have vista os
This topic hasn’t had any further discussion since October. You should not reply to old and dead topics like this. Instead you should start a new topic.
This one is now closed.
