do i just burn the lot to dvd then run the disk? im at a total loss
i should have been morepatient, think i figured it out, sorry for adding clutter to the boards
Since this post will come up when members search the topic, I will add this…
file.001, file.002 and so on, are either a compressed archive (open with Winrar), or a split archive (join with hjSplit, a free program).
Eventhough Winrar doesn’t recognise this file type as an archive, it will still open them. DO NOT join with hjSplit unless you are sure they are not compressed.
Yeah I was lucky, after researching the file type i downloaded hjsplit, luckily for me it didn’t recognise the first .001 file and after doing a bit more searching i found that i had to use winrar, well i was lucky do as suspect says run winrar on the .001 file first to save yourself from destroying the download altogether, if that fails you likely have a split file so then run hjsplit.
