Hi, running bitcomet 64 bit 1.52 version on windows 10. It was working fine then suddenly it would populate only the peers and no seeds for any torrent I download. I even added a decent sized list of extra trackers.
It’s perfectly possible for there to be no seeds available, but a lot of peers which total over 100%. One problem is that some people drop any ‘info’ files on the download - the result there is they show 99% of the availability and get classed as a ‘peer’ and not a ‘seed’.
If you're able to download the complete file, I wouldn't worry unduly.
