the floating window get disappear after closing bitcomet ,it signs again and again when restarted which does not happen in previous versions ,i think bitcomet team should improve it,
Thank you for your report, and it has been forwarded to the dev team.
This bug will happen in win7 64 bit os.
Once this bug is fixed, you will get to know from the changlog of a future version. ![]()
What does this mean? You’re saying the floating windows disappears when you close bitcomet? that is how it’s designed to work.
it “signs” (what does that mean)
I’m sorry, but I cannot understand what you’re reporting.
Apparently Ariel knows what he’s saying, so, at least that makes one of us who does. ![]()
Sorry… Moving fail on my part… I tried merging the double post and ended up moving all posts in a newer topic.
very strange, I didn’t see ariel’s post when I replied, but maybe it was the effects of vasy’s merge, but all is well.
I unapproved the confusing replies, one confusing post is enough lol
This topic was originally in the Feature requests section.
I first moved Ariel’s post into the one you replied to, so I could delete the useless topic, but it set itself above the topic starter’s post, being 6 hours older. So I said .. and moved everything from the new topic to the older topic and then I deleted the new topic and after that I moved the old one into the Bug reports section as Ariel said it’s a bug. In the meantime Wiz posted in the new topic and I had to move back his post from the trash. Sorry for that Wiz!
I did say fail..
