.70 bug with % done
I start the download, and the download stops at like 20% and reads as 6143726.1% and nothing can be done but deleting the torrent…
Other Bug:
I resume a download that was at 90 watever percent, when i resume its at 0 or 1 percent…
Neither of theese ive ever seen on any previous version of bitcomet
When you are resuming a download, if this happens, do a manual hash check of files and it should then continue from your previous level.
I strongly suggest you not install a newer version at this time.
I would also suggest you rehash this file reeding over 100%, but first I would shut down all programs and reboot your computer.
I would also suggest you run virus/spyware/adware scans, and also a good harddrive scan such as scandisc.
Yea the manual hash fixes everything
thanks
Very pleased to hear this :slight_smile:
