99.9 %
Im using bitcomet for a while,Im having no problem for downloading software,music or even dvds,but while im trying to download ..avi files almoust every downloads stops at 99.6% - 99.9%.The same thing hapened to other users I know.
Now what u sugessted me?
Is there any way to open that video file or should I make some changes in bitcomet settings?
If you check you will see in the peers that everyone is the same
sometimes this happens
  1. If the original torrent file is corrupt
  2. If it’s a bogus movie
3 No seeders remain with 100%
You can usually run the file ok in VLC media player once you have got a proper .avi extention to the file
get vlc at http://www.videolan.org/vlc/
to change your file ext, you alter the settings in windows
or better use the file property changer from my blog: called property cafe http://my.opera.com/caf4926/blog/show.dml/75377
then make a copy of the file you want to change to your desktop, drag it to the prop cafe to change the ext. enter .avi
Hi,
If you are using a router, and gaming mode is enabled, this can cause your problem.
Gaming mode does something to alter the files that will cause hash errors to appear, so the very last bit of data will never complete.
Read more here…
http://www.azureuswiki.com/index.php/Torre…p_at_99_percent
Also, some torrents are designed to fail, know as bad torrents. They usually don’t quite make it to this percentage, but you can read more here…
http://www.azureuswiki.com/index.php/Bad_torrents
Please let me know if I can assist you further.
