ok seeing how it says you can post here asking questions about anything ill take advatage of that but first all ask some bitcomet questions
1-kinda simple but still will having less simultaneous downloads increase the speeds of the ones that are dowloading?
2-ok last night i was kinda bored so i just decided on a whim to see if i could up the speed of bitcomet, so i search google find a site and go through all the things, change to static ip, disable UPnp mapping, use a use a patch os i can get my max half open TCP port open to 50+, so after doing this i run a speed test, it tells me that my dl speed is around 4000, and my upload is above 400, but i look at my p2p network and nows it only dlin 25ish kb. This is at 3 am so it should be at 150kb. So it being really late i undo everything and go to sleep. i just ran a test and its saying now
Download Speed: 758 kbps (94.8 KB/sec transfer rate)
Upload Speed: 194 kbps (24.3 KB/sec transfer rate)
So should i go back and see if it starting going up after like 30 min or stick with what i got now?
if you guys want the site were i got the info to change just ask
OK now the non bit comet related( i understand if you guys dont answer)
3-I got this refurbed hp m7334n MCE 2005 computer a little over a week ago and ive been having problems with almost as soon as i was able to use it, first of all about 3 days after it was delivered(well i had to pick up but whatever) media center cant find my hauppauge Wintv PVR PCI II tv tuner card, so after some troubleshooting with no avail i phoned up customer support and after a little more troubleshooting they said
to try reformat and see if that works. So i do and the tv tuner card works for about a day then goes caput(stop workin), now the second time it happend right after i installed some plugin then restarted, i dont
know if the plugins would effect it but i find it doubtful. Also whenever i start up my comp an error report will pop up saying that Media center reciever service has encountered a problem, etc, but no matter how many times i press dont send, send or debug it keeps pupping up. The second thing is with Media Center again, now after i start playing a movie/show(not recorded that is) off my HDD it will play for a few minutes then ill lose all controll, there will still be picture and sount but i cant pause, stop or do anything besides use alt-ctrl-delete to end media center.
One last question is im thinking of using System restore to see if that helps, but i dont want to use it if it deletes my files which now i have over 80 gigs of movies, pics, etc that i do not want to lose.
If no one can help, hp said if it keeps happening they’ll send me a replacement tv tuner card but if prefer not to have to.
,Thx.
