Hi!, i just wonder where the feature went that allowed you to choose what file(s) to download first (you could for example choose file 1 got high priority and another to have 50% priority and some to have low)or is it still there but you have to fix anything in the option?
Are you talking about Download Order or what?
Aye i think that’s the one my bitcomet got updated and it was gone, it was down next to the comments/peers/logs/trackers etc etc
Please understand that by changing these settings you will make the overall download less efficient. Your best to leave all files on “normal”.
I think you’re speaking about the Files tab in the Detailed Info Pane. If that’s the case, you can make any of the tabs visible by right-clicking on any of the tabs and putting a checkmark in front of the ones you want visible.
The update just fiddled with the layout. It did this to me, too. I thought it might have been to point out the existence of some new tab choices, but it’s easy enough to put things back, as Wiz points out.
Thanks for all the help guys, thanks ![]()
