If you could send me a link to where you got the movie I could tell you more about it.
as or kvcd movies, they vary in quality depending on who encoded it.
A good encoder can take a commercial DVD and encode it to 1/10th the size of the orignal dvd, and still look good.
I’m sure you can imagine this is not an easy thing to do.
Many downloaded movies are made form other then dvd sources, some are “cams” (taken with video recording equipment (camcorder). They range in quality from poor (crap, bad sound, fuzzy picture, people walking in front of camera, etc. ) to very good,
Some labled as “t/s” have a digital audio track added to a “cam”, or “t/c” (telecine) which is when the orignal film is scanned frame by frame. These ususally look very good, but not dvd quality.
The best quality would be dvdrips (made from DVD)
If you want to try some of the kvcd films from my release group (tus, the usual suspects), they are all listed on demoniod and sladinki trackers.
Most can also be found on Mininova as well, just do a search for “tus”, or the movie you want to find and “tus”
Our films are known world wide as being among the best, but be careful, there has been alot of fake “tus” movies made by anti P2P groups like MPAA and such.
Our torrents will be in .bin/.cue disc images and never zipped or .rar.
Here is a link if you want to take a look at some…
http://www.mininova.org/search/?search=tus+release
ps. I gave you this info because its the easiest way to tell if a movie is good quality, tus won’t do a movie if the source is bad,
