about downloads
alright im kind of new to this… i was just wondering why do my particular torrent files go past 100%? for example on of my files its stuck at 296.5% …
Hi random,
Are you sure this is the percentage downloaded that this figure is refering to?
Could you please make a screenshot and host it on a site such as Imageshack?
If there is a problem with your version, it will be passed on to the developers, so getting a screenshot will be helpful to them.
I would also compare the total file size/s that you have downloaded and compare this to the correct size they should be.
