About port forwarding
after making port forwarding i opened a “statistics” in bitcomet ver 1,16 i saw this massege "
Overall Tasks: Total:8 / Running: 1
TCP Connections: Established: 43 [MAX:Unlimited] / Half-Open: 0 [MAX:18]
LAN IP:
WAN IP: 41.238.100.55
Listen Port of TCP: 24504 (Opened in Firewall/Router)
Listen Port of UDP: 24504 (Opened in Firewall/Router)
Windows Firewall: Added [TCP opened, UDP opened, TCP(ED2K) opened, UDP(ED2K) opened]
NAT port mapping: wating for query IP address
Overall Download Rate: 29 kB/s [MAX:Unlimited] Max Connection Limits: 50 per task
Overall Upload Rate: 10 kB/s [MAX:10] LT Seeding: 0 kB/s [MAX:3] All BT Upload Slots: 5
Free Phys Mem: 92.73 MB (Min to keep: 50 MB)
Disk Cache Size: 48 MB (Min: 6 MB, Max: 50 MB)
Disk Read Statistics: Request: 1779 (freq: 0.1/s), Actual Disk Read: 273 (freq: 0.0/s), Hit Ratio: 84.6%
Disk Write Statistics: Request: 19545 (freq: 1.4/s), Actual Disk Write: 305 (freq: 0.0/s), Hit Ratio: 98.4%
Total Downloaded: 8.92 GB
Total Uploaded: 1.14 GB
please is everything is OK???
From the statistics it looks like you don’t have a router, so… where did you do the port forwarding?
You’d better read and post all the specs from here, if you need a 100% sure answer.
Have you set a static IP too?
:mellow: I have a router model " CNAD 804 NF Cnet
and ADSL 512 speed and static IP
Is your router in bridge mode?
NO
Well, then why doesn’t BitComet report any LAN IP?
What is the IP of the network card you use for connecting?
