about seeding
I’ve just finish downloading a file, now i’m seeding. The seed/peer is 0/40[58/1962] and the ratio is 3.9
i was wondering when do i need to stop seeding or do i just let it keep running?
the minimum seeding ratio should be 1.0, or if you want to be a good peer, then 2.0
you have done a good amount of seeding and you can stop if you want
however, if you really like the file and just want to share it to many people also, then it would be very good to keep seeding
