I’m using version 1.28 for BitComet. My ISP is a cable isp with unlimited bandwidth at rated at 15mbs (usually I get twice that). The router is a Netgear WNR2000v2 hardwired into a Motorola SB5101 modem, which is connected into my computer. The modem itself is hooked into port 4 of the router. I’ve tried unchecking upnp from both the modem and bitcomet. Nothing. I’m on windows 7 32 bit with the latest updates (I will admit that I’m just using the internal windows firewall and most recent version of Microsoft security essentials). I’ve been working with the software from Port Forward, which you can see here: http://screencast.com/t/vQJLYqXu8t (these are the actual settings). I’ve also forwarded 141492 apparently successfully as you can see here: http://screencast.com/t/kFbQjOPQPrh.
I also use HideMyAss Pro, which works well and connects to 66.90.122.154 (illinois) and that I also use for work. I get decent speed I guess (around 80 kbps {much better than when I was with a BIG telco!] but I’m still blocked and have the yellow light. I must be missing a thing or two, and could use the advice. I just want to get the best speed I can get.
