It’s saying that the files I am trying to download have no peers or seeds on them. Any file. It says connecting, and just stops there. Weird thing is, it worked just fine yesterday…
If you don’t successfully scrape the tracker, you won’t get a list of the swarm members from it, so of course, no seeds or peers. Look at the trackers tab and see if it’s giving you an error message.
same thing just happened to me. I can connect and it shows under trackers that i have connections but I have no seeds and no peers.
worked fine yesterday.
Well, for some reason it works now. Maybe that small bit of spyware was boging it down or something. Try running Ad-Aware and Spybot - S&D, and also AVG. It seems to have worked for me.
