Adobe Flash plug-in crashes
My Adobe Flash Player plug-in keeps crashing. I’ve uninstalled and reinstalled Flash Player several times over the past 10 days, but it still keeps happening. Any suggestions on what I should do? Thanks.
THis is likely a conflict with something else. I suggest you disable all of your other plugins, then try again.
Adobe flash crashes often, usually a result of the content you’re using it with. Sometimes the problem is with your systems resources, it might be consuming all your memory, or could be some bad programming, but this has nothing to do with cometbird, you should inquire with Adobe, or the publisher of whatever content that’s causing flash to crash.
