Hi there,
Seems there is another issue with the new bitcomet 0.68 (getting urge to switch back to 0.61
At advanced properties on a torrent you can setup task settings such as minimum upload and maximum upload. The problem is the button that scrolls the numbers is broken. If you click on it , it disappears. Seems the onclick event or child window property is broken?? Please check this. Thank you for your time.
Cheerss
SSJ
