After upgrade to SP2, slow download..
I upgrade SP1 to SP2, i notice my bitcomet slow down around 45KB/s drop to 10 - 15KB/s.. what wrong??
then i go and surf the net, it load very slow compare to last time when i using SP1. My connection is 512K, not using router.
What wrong?
are you sure you have done the right settings for bitcomet?
I using 512K connection.
Global Max Download Rate: No limit
Global Max Upload Rate: 19 kB/s
Proxy Type: No Proxy
Max Connections per Task: 50
Connections to keep per task: Auto
Global max upload slots: 7
Global min upload slots: Auto
Max half-open TCP connections: 50
Max Disk Cache Size: 50 MB
Shrink Disk Cache if Free Memory Lower than: 50 MB
someone help??
Now that your using SP2, in Bitcomet you need to lower the max half-open tcp connections to 8.
or you could look into using the lvllord patch which works fine for XP SP2, read here
For SP-2 you need to set this somewhere between 5-8.
You Max upload should be set at 80% of you upload limit to get the best overall performance.
If you have anymore questions read through our settings guide and faq.
