Allow seed time > 1000 minutes
BitComet’s maximum time to seed has been arbitrarily topped at 1,000 minutes, or 16 hours and change.
There are sites that require seeding to a minimum ratio (which is almost never achieved) or a minimum seeding time of 48 hours.
BitComet could easily accommodate this by raising the maximum seed time. There’s no good reason that I can see for the arbitrary limit of 1,000.
If there has to be a maximum below the field datatype, it should be at least 10,000 minutes.
I got u. I’ll convey your idea to our technical director. I believe he will consider this since it is really a contributive request.
In the meantime you can happily use the “Bypass seeding rules” option on the properties page of the task to set it up for seeding indefinitely.
That’s basically, “keep seeding 'til I remember to check and stop it.”. Works, but is not ideal, especially if you have other seeds waiting their turn.
