Am I seeding?
What does the seeding icon look like? I’m seeding something (at least, I think I am) and it says that the file has no peers. Not even me.
Maybe I did it wrong? I use BitComet and Shareaza, both of which have different download directories. I put the file in my Shareaza download folder. Should I move it?
The default seeding icon is an upward-pointing arrow colored orange/red. If you’re not seeing that, you’re not seeding.
When you load a torrent to seed it, you need to set the save location correctly. That can be any reachable path on your system, but it must be correct. When the torrent is running, it should show that you have 100% of the file. If not, you’ve got the location wrong and need to try again. It doesn’t matter that you’ve moved the file(s) from the default download directory provided you tell the torrent where you moved it to when you start seeding.
