Ok, so I’m having a bit of trouble here. I downloaded Adobe Photoshop with BitComet. Now I’m having problems with opening the actual program. I took a screenshot of the file. I can’t seem to open anything. Sorry if it’s a stupid question I just have never done this before. Am I doing something completely wrong?
Frequently Asked Question. Frequently given answer.
It’s OK, everyone has to start somewhen ![]()
http://img83.imageshack.us/my.php?image=aps4ew.png
if all else fails - try the gimp
If yo open the MSinfodocument with notepad it should say how you should do.
But if it doesn´t
Do like this.
Burn it to a disc.
If you use Nero
Nero Startsmart
Backup
Burn image to disc- choose nero express
image, project,copy
disc image or saved project
go to the location of your file and choose the .cue-file
Burn.
That the way to do it.
You can open bin-files in WinISO or PowerISO
good luck
