Hi,
i have a problem,
When i start Bitcomet, i get an message :" Can not listen to port 9515 ".
This port is my tmc, for the firewall.
How can i solve this?
Greetings,
Hi,
i have a problem,
Greetings,
Ok, I don’t know what “tmc” means.
Anyway first you should set BitComet to use a port between 50,000 & 65,000 to avoid conflicts.
Now, what firewall are you using? Do you have a router?
