i was testing qbitorrent and i liked it somehow, because of the disk Cache Settings, let it Speed up very fast the download, and the anony mode, letting out the digital Fingerprint in torrents.
Interesting Feature to bitcomet to add?
Qbittorrent explain anonym mode like this on his site:
When enabled, qBittorrent tries to hide its identity to a certain degree. The peer-ID will no longer include the client’s fingerprint. The user-agent will be reset to an empty string. Trackers will only be used if they are using a proxy server. The listen sockets are closed, and incoming connections will only be accepted through a SOCKS5 or I2P proxy (if a peer proxy is set up and is run on the same machine as the tracker proxy). Since no incoming connections are accepted, NAT-PMP, UPnP, DHT and local peer discovery are all turned off when this setting is enabled.
