Application FAIL!
Every single link on bitcomet doesnt work. It says “Application Failed” I uninstalled it and tried again
but no… it still doesnt work. And how do you change the NAT setting or something , all of a sudden it h*** slow and
it says check firewall and NAT settings? Does anyone no why bitcomets links isnt working and how to change NAT?
I don’t feel like I have to make an epic attempt to try figuring out what you’re talking about. Maybe someone else is willing to, but not me. I figure it’s up to you to explain yourself. What’s a “link on BitComet?”. You change the NAT setting or something by reading the FAQ or something and the wiki documentation or something. BitCcomet works very well, but can’t overcome so much pilot error.
It’s free software, and you have to work hard to understand it and use it. If you don’t want to do that or won’t, then don’t use the software. Nobody gets paid for their efforts, and nobody is willing to coddle you. If you can’t even put forth the effort to clarify your questions then I suggest you give bittorrent a pass.
