Please ask questions in a “new topic” rather then replying in another members topic.
Tomonori,
I’m not aware of any bugs in version .70 concerning this.
I do recomend you NOT use versions .71 or .72, as they are not considered “Stable”.
I am using version .70 on this computer, and just changed my defaut client to another client, and bit comet did not change it back as you report.
I’m not sure why your client is reverting back to bit comet as default.
I suggest you try to manually change the “opens with” option in windows, and select what ever program you want to be default, see if it works that way.
I also do not have a windows 2000 system handy to test this on, but pehaps another member or staff can be of more help.
First of all I did not say there were any problems with BT .70, which is why I’m looking for that version. I stated that problem is with BT .72 and not the error you mentioned about it reverting back to a new default. I don’t know where you got all that from the few words I wrote. There is an error at the BT site when you try to download BT .70 and I can’t seem to find it anywhere else.
To IronicRhetoric:
“The UnUsual Suspect” told you where to get BitComet 0.70 .
