I have recently downloaded audio files. When it was downloading, the files had the extension .ape which after 100% download converted themselves to .m4a file format and I could play it with iTunes with no problem.
I have downloaded another set of files but even though a 100% download was effected, the files do not convert to .m4a
Is there anyway I can convert the files manually?
Thanks
Here is a free program for converting .ape files
http://www.shareup.com/Ape_Ripper-download-37733.html
I’ve never used it, so can’t offer any opinion.
Thank you. I downloaded Ape Ripper but I was not successful in converting the .ape files. An error occurred.
Wonder if there was a missing exe file that prevented the automatic conversion of .ape files to MP3 format?
Wonder also why it did not automatically convert the .ape files? Cannot be a bug since Bit Comet 0.70 automatically converted .ape files to .m4a format on an earlier download.
Wonder if I should download the file all over again?
I was able to eventually convert the .ape files to .mp3 format using a FREE MP3 wma converter available at http://www.softpile.com/Multimedia/Audio/D…ad_46632_1.html
It works just fine
