Hey, using v1.29
in the main window if i want to arrange the size on the columns, after moving to the right or left, all the columns auto expand themselves again and it is very annoying ![]()
tnx.
Hey, using v1.29
tnx.
It appears only the “torrent name” will revert back to default size when others are changed. You can adjust the other columns, then adjust the “name” column last and it should work.
