I’ve been using bitcomet for at least 2 years without problem. However over the past 2 weeks the program will log on, begin downloading as usual, but after 3 min will shut itself down. The icon in the system tray stays on until you drag your over it then it will disappear. I began having the problems with vs. 1.21 and hoped that the upgrade would fix the problem but unfortunately it still does it. I have tried both sprint wireless aircard and my sprint HTC Evo which was working fine before 2 weeks ago. The port is automatically set to find per the program. I use Windows Vista and PC Tools as a firewall and have the windows firewall turned off. The speed test results where - ping 317 ms, d/l was .96 mb/s, u/l was .39 mb/s, ISP Sprint PCS. Event log showed event ID 7036, Admin events - error source CAP 12, Event ID 11. And System - source PCT Core Event ID 267. Whatever help would be greatly appreciated. Let me know if you need any more info. Thanx!!
Event ID 11 is some flavor of controller error. There should be more detail there.
When you say, “shut itself down”, what do you mean?
Hmm… weird.
Have you checked first that the Auto-Shutdown function, under the *Tools *menu is disabled?
If that’s not the culprit, I would incline to think that BitComet is being closed by another process (i.e. your security software, perhaps). If it would crash, normally there would be a crash report built.
You should try to uninstall whatever, security software you have installed (PC Tools included) and see if it still does that.
Also, when you double-click on a event in the event log you will get a more detailed explanation of it.
Try re-installing BitComet ?
Or if its not latest version.. try get that .. not an expert but that’s what i’d be doing from the start
I have the same issue. Please help
But I seriously doubt that you have the same setup, sooo… start your own thread, please, after reading THIS ![]()
