I commonly will have more than a dozen torrents queued up, and one thing that would be REALLY nice is an auto-stop.
For example, I want to DL 10 torrents, and only have the connection to handle two at a time. So if I could set my limit to two tasks, and then set a torrent (global or local, either would be fine) to stop after it has seeded past a certain point (say 1.5x or 2.0x), and then let the next torrent in line continue automatically would save HUGE amount of time.
I see that you have accepted a suggestion for “A way to control the number of seeding tasks.”, and I think this would be a good way of doing it. It should also be fairly easy to implement, no more than a few lines of code….
It would also give folks looking to “order” there DLs an easy way to do it with minimal effort.
http://forums.bitcomet.com/index.php?showtopic=1795
What do you think? I know this is considered a low priority, but, it would be so easy to implement.
