Bad Data and more...
Hey guys,
I’m getting tons of bad data which i guess is nothing unusal to an extent. However most of the bad data is comming from an ip range of 38.100.. there is over 40 ip addys <_<
I’m pretty dogded about these IP’s there’s usally a few of the same IP’s in the peers but never this many.
Smells a little fishy. (what do you guys think?)
So…How do I block this Ip range with IP.dat or hosts file?
and FYI my Bitcommet version is 0.70 .
Ragards
Mafisto
use peerguardian 2
if necessary add the ip address to your lists
use peerguardian 2
Thank’s for that :smiley: seems to have done the trick.
Regards
Mafisto
A quick note for PG2, only use PG’s lists. These 3 to be exact: p2p, ads, spyware. You don’t want to block the education ranges because that also blocks guys using their college’s high speed lan. Don’t use any of the lists from bluetack. Theirs are very bloated and some of those guys are real jerks.
