BAD REQUEST error when making a Comment
Hi. Since about a week I am not able to make comments in BitComet. It produces the error message
BAD REQUEST The CSRF token could not be verified. The request could not be understood by the server due to malformed syntax.
It used to work fine.
Any idea what could be the cause of this?
Technical data:
BitComet (64-bit) 1.35 (latest update)
internet speed 10MB/sec
Modem: Zyxel P-2812HNU-F1
Windows 7, 64-bit
Thanks,
Henk van der Nol
I suspect the server is having problems, I’ve been having issues with the forum too which may be hosted on the same server. Give it some time and see if the problem clears up.
