Bad Speed and Error
I’m currently receiving very slow speeds of only 7kb/s.
i think this maybe the issue
Default tracker optimization rules file loaded.
IP rules file: ipfilter.dat loaded, 0 entries.
Start Listening at TCP Port:49491
Start Listening at UDP Port:49491
BitComet 0.70 is running on:
CPU : Intel® Pentium® M processor 1.70GHz 598 MHz
RAM size : 1,015.37 MB
OS Version: Microsoft Windows XP Home Edition Service Pack 2 (Build 2600)
Windows XP WF Status: TCP Port is opened in Windows Firewall.
Windows XP WF Status: UDP Port is opened in Windows Firewall.
Update Local IP: 192.168.0.2
Windows XP ICS Status: cannot find working ICS.
Windows XP UPnP Status: device not found!
UDP tracker report: WAN IP = 58.162.3.122
Can You Help???
all my peers are local too
While BC is running go to this site and enter BC’s port. canyouseeme.org. What security software are you running? You should also consider looking through our settings guide.
