Ive downloaded BC 0.71 Client (the first one on the downloadpage) and after around 20 min all downloading stopped! Anyway downloaded from many different trackers from 7 different torrentsfile..
Ive went on every torrents file to look if the trackers found any new peers, all found but still they wouldnt start it! Ive also tryed to reboot the comp and program some times without effect!
(dht network wouldnt respond due to no firewall still installed)
Afterward i downloaded 0.70 and it worked fine again.. dont ask me why but im sure it is a bug in 0.71 that wouldnt start the downloading form the peers..
I believe I have the same problem. Bitcomet works perfectly when theres seeds, but when theres only peers it does not dl off them. I have tried on about 20 different torrents already and only the three that had seeds worked fine.
