belkin 7632-4 help
We have had a new router, the above and now the speed has disappeared for downloads
I have set up port forwarding for the belkin router. checked out loads of posts but nothing seems to work…
Can anyone help me with this as i am pulling my hair out.
thanks in advance
Mark…
system: win xp home sp2 all updates
When you start a torrent are you able to connect to the trackers? (look in the Trackers tab, any errors?)
after it connects to the tracker are you able to connect to Peers? (look in the Peers tab)
after the Peers start connecting do any of them become “Remote” connections?
Have you gone through our Settings Guide? (link in my sig)
I have followed your settings exactly as shown. I still have speed of 1kbs!!!
I have attached a screen shot of whats happening to see if you can shed any light on the problem.
some of the settings are:
Tracker response = ok
connected seeds = 10
connected peers = 10
connecting peers = 0
down rate = ikbs
Thanks in advance,
Mark
bitcomet_screen.doc
Dont follow my settings exactly you need to adjust some things for your connection
That torrent has very few seeds and leechers which means it is never gonna be that fast and 1KB/s may indeed be all that you can get from it.
So you are getting “Remote” peers right?
Try downloading a torrent with more people connected to it to see how fast you really can go.
Here is a good torrent to test your speed with
http://distribution.openoffice.org/p2p/
Also I have sent you a PM
I have used the torrent supplied but it seems to be still very slow. its around 15kbs.
Before using this belkin router speeds seemed to much faster.
I have attached a screen shot again to see what you think.
thanks for your help
mark…
bitcomet_screen_shot_2.doc
You havent answered my question
Look in the Peers tab
are you getting any Remote peers?
or are they all Local?
If they are all Local that means your portforwarding didnt work and that will really slow you down
Also if you post anymore screenshots please upload them in .JPG format
Thank you for the reply.
Yes there are lots of remote and local peers when i click on the Peers Tab. Screenshot attached in jpeg formt
Regrads,
Mark
/post-14269-1162811277.jpg" rel=“”>
BUMP
Ok, good you’re portforwarded properly.
Lets try some things:
can you please lower the number of peers you connect to, try 50 for max connections per task
Also Uncheck the DHT Network.]
(maybe the belkin gets bogged down if there are too many connections)
(while you’re at it make sure that you have the latest firmware for that router)
Now shut down bitcomet and then start it up again.
Dont expect to get awesome speeds with that torrent you posted, it isnt very well seeded.
Belkin Setup Configuration guide to configuring your extender with IP address 192.168.206.1. Learn how to configure a Belkin setup using 192.168.206.1. If you’re ready, you may move on to the Belkin range extender setup instructions that are covered in the given Link.
Source: **[https://belkinsetup.unicornplatform.page/](https://belkinsetup.unicornplatform.page/)**
/monthly_2022_06/Screenshot.png.9924c8a04e2f13dc66a33f7919162c8d.png" class=“ipsAttachLink ipsAttachLink_image”>
I think that after SIXTEEN YEARS they have either fixed the problem or got another router.
It's not a bad idea to check the dates on a thread before jumping in
Date of thread: **/topic/3945-belkin-7632-4-help/?do=findComment&comment=14407" rel="">October 31 , 2006**
