i need help with BIN files i just downloaded a program that is a BIN File how do i get it to run what should i do??
Cheers ![]()
Cheers ![]()
In most cases, a .bin file is one part of a two part disc image.
.bin/.cue work together. The .bin is the disc, .cue is the “cue sheet” (instructions for your computer to burn the .bin)
If you cannot see the .cue file, then go into “folder options” and uncheck the “hide file extensions for known file types”
ps. there is a slight chance that yours is not a disc image, but without a complete file list of the torrent, I can’t say for sure.
I have a bin/cue file should i just burn the bin file and the cue will work by itself or what should i do with the cue file??
its the .cue file you select when burning disc image. Its the cues job to tell your burning program how to handle the .bin.
Just do not change the name of them, and keep them in the same folder and you will be fine.
the .cue file is the only one that comes up when i try to burn disc image if thats what you mean so i should just burn that?
Yes
Thanks for that! ![]()
