Hy ,i have a problem with bit comet,the program doesn’t want to download torrents,if i try doing that nothing happens the torrent appears there and shows that is connecting,if someoneelse send me that torent it works the file is downloaded succesfully,i dont’t know what to do to make it work.
Hi, I recommend you to tell us more detailed infomation so that helps us to better understanding your problem. You may read this first.
