I hope someone can help me I’m doing my best to write in English!
Everytime I try to download with BitComet it open a second BitComet and a message appear saying that bit comet has stop working and windows will closed the program..
I use FireFox, Windows 7,64bit.Bit Comet 64 Bit 1.35
I even tried with internet explorer and the same result
Please Help, I’m not a pro with computer!
What type of task are you trying to download?
What do you mean by “opening a second bitcomet”?
I try to download from Pirate bay mp-3. I clik on “get this torrent” like I usualy do the song appears on my Bit Comet and then the image whitens before I have time to press download now, a message appears saying that BitComet.exe has stoped working correctly and window will close the program (all that in french) and advise me it their is a solution available, but it never happen windows doesn’t find anything to help
It will open a second BitComet if I open BitComet before searching for MP-3.
Have you recently installed some software before this problem surfaced?
This is probably not the case but… I, personally, have had the issue of “It will open a second BitComet if I open BitComet before searching for MP-3.” with several programs and documents before. It had nothing to do with the applications, but did with the speed that my mouse was clicked.
What I mean is that my daughter clicks the mouse buttons far faster than I do and, for some unknown reason, it would duplicate whatever process that I was trying to perform - whether it be opening a document, starting an application, or anything else… all that would happen is that two instances of the same action would occur. The problem was solved by getting a new mouse and making my daughter use the touch-pad instead of my mouse…
No but i’m thinking of maybe to format my pc.
What I dont get thow is that I’m able to download in direct mode.
Everithing else works great.
It’s difficult to understand exactly how you are starting your tasks , but I think somthing is redundant in the process so please open bitcomet options and look at: Task>http/ftp page and if the box for “create BT task after download of torrent file” is checked, uncheck it and see if that makes a difference.
Guys everything that I download now just stops at 99% please help
@darkmastertk
Please do NOT jump into the midddle of someone else’s post with something not related to the original thread (very rude)… please start a new thread of your own.
@darkmastertk, please also read the rules for requesting support, you can find the link below in my signature.
