bit comet restore
To whom may help me :smiley:
I need some advice on HOW to put files back into bit comet , so other’s may SEED from me, as I have GB’s of upload to use… :wink:
I know HOW to take it out of folder, BUT not put it back so others may seed>> <_<
Hi there.
It’s easy. Just open the .torrent you are going to seed and choose the “Save location” to be the folder where your completed file(-s) is(are). BitComet will verify that they are unmodified, and after that you may seed by pressing “Start” button or double-clicking task name.
BTW, check some FAQs, like this one. They are informative :slight_smile:
