i have bitcomet 0.70 software but it is no connecting plz help me or give me new full and complete register version thanks
this problem is usually caused by your firewall blocking bit comet. You would need to give it full inbound/outbound in your firewall.
and when that’s not the problem?
To give a full and complete answer to these questions, I would need a lot more information as to what the problem is.
I have seen quite a lot of new users that attempt to run a torrent with no seeds or peers and wonder why its not working. If you don’t know what this means, then you really need to do some reading about bit torrent…
http://en.wikipedia.org/wiki/Bittorrent
That link will connect you to link after link to anything you could possibly want to know about bit torrent protocall.
If you have a healthy torrent, and a correctly installed bit comet, and have given it access in your firewall/router, then it will work.
None of the members who posted in this topic have even mentioned if the torrect is active, if they have a router, if they are using a firewall…
To simply say “it don’t work” and want us to tell you how to fix it is not possible.
