BitComet 1.22 freezing
In 1.21 bitcomet sometimes froze for several seconds saing disk is ful (but that is probably just my computer) but when I installed 1.22 it freezes when I try to stop download, dowload is finished, or many other stuff. Please fix it!
Thank you.
Sounds like BC is writing to disk, which it will do on those occurrences. If your drive is nearly full, this can cause delays as the drive searches for free space to save to. It should give you a “disk busy” popup when that happens, though.
