BitComet(1.37) High Resolution(2560x1440)
I have high resolution monitor(2560x1440) (Personal Settings: Control Panel\All Control Panel Items\Display - > Larger).
Problem is personal are different font(see flowing image):
/monthly_06_2014/post-97534-0-32299000-1404130979.png" rel=“”>
Also same problem is on properties window.
Same problem here. Even at lower res (1080p) i can not see many texts..
If your windows settings are at or near default you shouldn’t have this problem, bt if you are using large text and icon size you will run into similar problems with many applications. This is a case where if bitcomet was optimized for high resolution screens it wouldn’t be useable for the majority of users. Any simple solution would have to be done on the operating system side as if it was done on the app side it would require an understanding of complicated options as well as a lot of work in development and documentation and we can’t even get most members to read the documentation when it’s kept simple. Of course you are welcome to make a feature suggestion for users with large text settings, but I can’t promise it will be a priority.
