I`ve noted two problems since using new version 1.40:
After installation programs starts lagging, significantly retarded responce to mouse clicks. Reinstalling te programm helps for a week or so. (I have approx 90 tasks running)
When starting new task it doesn`t show in the task window. When I restart the task it reports that file already exists. Clos and reopen the programm helps till the next task is being started.
I have the same problem here. I just realiesd that all my task’s are missing after update… and bitcomet i very laggy, my mouse click is like 3 sec delay. Im on windows 10, using ssd for win, and normal hdd for bitcomet and downloads
Most of us do not suffer this problem, but if a member has a problem he should make a new topic describing the issue after reading the “READ THIS before posting” topic and including all the details and we can try to figure out what is causing the issue.
I used to have that issue, I sorted mine by actually reducing the Download speed, Tasks may be lagging the BitComet window out if your download speed is set to high.
I’m on a fibre optic 50+MB speed, and if I allow Unlimited speed & only one task then it’s virtually impossible to select anything at all. So I reduced my download speed & it’s fine.
There’s no points or prizes for who can download the most running tasks at once, and your up is capped anyway, So slow things down a bit & everything runs just nice & smooth.
