Hi, I am using version 1.37 on windows 8.1 64bit. Over the last few days when i start a torrent it immediately moves it from where it is to the bottom of the bitcomet list.This has never happened before and i haven’t changed any settings recently.Also recently it appears to be downloading but after several minutes the percentage doesn’t move.Also i have the client set to only run one task at a time which until a few days ago worked but now the setting doesn’t seem to be working.This has all started happening over the last week. Like i said i haven’t changed any settings recently.If you need any more info let me know.Thanks If you have any suggestions it would be appreciated.
I find it difficult to understand your post, but my guess is you have the task list set to sort in a different order than you’re used to. If you click on the top of any column it changes the sort order, clicking again will cycle through the available options.
hi thanks for the quick response.I feel pretty stupid your suggestion fixed it.I was putting too much thought into it(not enough)lol. I think the cat has been messing with my keyboard again.Thanks mate.
Who me???
No, I typed KITTY p***… damn this auto correct!!!
Grumpy Cat Wisdom!!!
Oh, sure, sure…blame it on the cat… <_< :lol:
