If I connect my PC directly wired to my router, downloading with Platinum Hide IP running is not a problem with steady speed of 2800 kbps.
If I will remove the wire and use wifi connection, I get 0 kbps.
Under Option–>Proxy Type–>http1.1. Proxy server and port are automatically filled.
Is there something I am missing??
Please help.
Try restarting all your equipment.
Rebooted everything including the modem but it is still the same,no connection.
Is your problem no connection or bitcomet isn’t working? If you have no connection you’ll need to diagnose the problem with your wifi.
If your problem is only with using hide-ip, I’d check with their tech support
Yes that is a good idea, I will check with their tech support.
Thank.
