First I downloaded Bitcomet 0.99 from ISO Hunt. seemed to be allright.When
I went to Register to login the Page came up in Jap.so I removed the 0.99.
then I downloaded Bitcomet[20060908] I logged in Through the web page.
But on Bitcomet screen on the bottom it says (Not loginned in)whats this?
Also with the 0.99 Version it had the scan option and the [20060908] Does not.
Why is this?
Thanks Studly256
Bit Comet 0.75 is available for download on FileHippo.
Is this a beta version or the long awaited update to Version 0.70
Just been made aware that Version 0.70 is the last stable version.
I strongly recommend you only download bit comet from bitcomet.com , or our archive site.
If you get it from a third parties torrent, we have no way of knowing if it has been altered/infected with spy/adware/viruses.
As for logging in, this is a new network being setup in china, and doesn’t apply to other areas yet, so please just ignore this option.
Also understand that versions .71-.75 are not stable releases, so use only if you want to try something new.
http://www.bitcomet.com/doc/download.htm
Furthermore there is no version 0.99. So you should run scans for antivirus & spyware.
nourah
November 16, 2006, 10:40pm
6
helllo
hellllp hellllp???
i really need help bacause>>>>>>>>>>>>>
i dont know >>>>>>>>>>>>>
how 2 use it>>>>>>>>>>>>>>
pls if any one can help me
would pls add me in her or his e mail
novision2005@hotmail.com
cassie
November 16, 2006, 11:33pm
7
I’m assuming (as we are often forced to do, when people don’t make any reference as to what they’re talking about) that you mean to say that you don’t know how to use the link provided by Suspect?
If this is the case, just move your cursor over his link and click on it. It’ll take you to the site directly.
If this isn’t what you meant, please specify.
cassie
