Bitcomet deleted all my files....please help
Hey guys,
Great program, i just switched from utorrent to bitcomet.
Ok here is my BIG problem:
Once you finished downloading a torrent and close the program, when you reopen it all the torrents that youve DL are coupled with a green circle or ball meaning stopped. I pressed start, thinking that i would seed the torrents, it actually restarted to DL all my torrents!!
I went to the designated download folder, the folder or Rared files are there but with non existent data. 0kb etc…
What did i do wrong and or how can i recover this data?? It seems as a result of this , bitcomet deleted all my torrents, can i recuperate them? There was so much work involved here…also i downloaded torrents of trackers wich include a ratio…
most probably my mistake…
Help please!
THanks , VP
I have the same problem too. I chosen to delete a task + all torent files, but I don’t mean it. Please help me to restore them. I have spend so much time to download them :frowning:
I think you can open the task properties and on the general page change the task from download to seed and hit ok. That should work :smiley:
Hey Geisha Girl,
You really got me going when i read your post. I tried it, but it doesnt work. The files are actually missing so i can not seed!
Bitcomet actually deleted the files…i think its a program flaw cause when finished downloading it should go directly to seeding…instead it goes to a stopped mode…when you press start again by default it will erase the torrent and files and start downloading it again. Terrible programing if you ask me…
Thanks anyways…:slight_smile:
Hi vpmitchell,
What version are you using?? :unsure:
