I tried to download something so I started by clicking start on the task. But then a red “X” icon changed showing ‘The system cannot find the path specified’. What does it mean and how can I fix it?
Well, that is very well covered in this Wiki FAQ topic.
You’d better always check the FAQs before posting for help.
There are a lot of problems listed but I don’t think any of them are the problem. I’ve tried deleting the task and downloaded files then downloaded the .torrent file again and it still doesn’t work. Starting other tasks worked though and they were all saved in the same folder, C:\Downloads
Well, what you think isn’t of very much relevance to us.
However, other **facts **such as your OS type, your BitComet version, your storage media type that you use for BitComet, might be. B)
Moreover, what’s the path of the task on the Summary tab or on the properties page of the task?
