bitcomet UI hangs frequently(about 10 seconds). I do not clear the torrent collection so that I can search for something other shared. so I have about 310k torrent in torrent collection and torrent share. Is it the root cause of hang?
Do you mean you have 310,000 torrent files or 310KB shared files? I sincerely hope it’s the latter LOL
Hanging - there could be a number of reasons -
you're upload speed is too close to your maximum set by your ISP and there is insufficient bandwidth for receiving staions to 'handshake'
you may need to increase your swapfile capacity
your anti-virus may be scanning the files (I download to a separate hard drive and only scan when opening a file (the destination drive is excludedfrom automatic scanning)
you may have insufficient space on your drive for any temp files needed
310,000 torrent files .
Upload speed - not the case.
swap file - not the case
anti-virus - Not sure. Seemed not the case. Installed Tecent computer management software. but closed Tecent computer management software when I ran Bitcomet.
Disk space - Not the case. There is enough disk space.
I tried to restart Bitcomet and seemed to be better. It did not hang for about 10 minutes. Will see how long it lasts.
Unfortunetely it hang again after several minutes. Closed it and restart. Version 1.63
I would seriously consider stopping a lot of files. In fact I’m surprised to can manage any transfers - the amount of sheer processor power and bandwidth needed would be horrendous.
My 'rule' here is, unless it's a file that I'm personally seeding, I automatically stop all uploads when I have a 4:1 ratio
No. You misunderstood the case. It is not the uploading. It is torrent exchange → torrent collection and torrent share, I had more than 310000 items in torrent share and torrent collection. It became hang every 10 seconds. I clear everything in torrent share and torrent collection, and the problem is gone. I think there was some problem in the torrent share and torrent collection. You may change it to background threading so that it does not block the UI.
It’s still a huge number - as you said yourself, clearing the files fixes the problem. Did you try reducing the amount and see what happens then?
I think I have the same problem too though it could be just just one of the tings with laggy UI. My hardware does not bottleneck BitComet at all, though only my Windows 7 does.
