Bitcomet help, torrents wont start
Everytime I click on a torrent file, my Bitcomet opens up and I get this message:
“Unable to read torrent file! Please try re-downloading the torrent!”
I tried everything, I dont know the problem.
Please provide which version you’re using, AT LEAST. What you’ve posted doesn’t really give any information to work with.
What exactly is it that you’ve tried? What were the results?
Thank you.
cassie
Thank you.
cassie
Im having the same problem. its the newest version .70
All right, it seems that I was not very clear, on my previous post.
You have version .70. Fine.
Now:
What O/S do you have? Who is your ISP?
Do you use a router and/or modem? Which one? Is/are they portforwarded properly?
Do you have an antivirus? Which one? What type (internal/external)?
Do you have a firewall?
Have you already gone through the SETTINGS GUIDE??
If you haven’t, I strongly suggest that you do so, before posting anymore vague questions.
Once you’ve done THAT, if you’re still having problems, THEN make a thread, with DETAILED explanations of your findings.
cassie
