I’ve noticed my physical memory usage (watched it from task manager) keeps rising as long as my bitcomet is open, i tried leaving my computer on with bitcomet closed and my memory stayed the same (did not rise abnormally)
i’ve read somewhere in this forum that this is normal (for some reason i can’t recall), the problem is it wont go back to regular levels (around 25%) after completely closing/restarting bitcomet, it will only do so after a fresh reboot of my computer
its bothering me because im seeding 24/7 (= memory always rising) and i hate to have to reboot every other day
every time it reaches 40% and higher it’s starting to effect my computer performance (=takes more time to do things, audio/video jamming, gets stuck for a short while) and it becomes unbareable after a day or two
I’m asking for help at this forum because i can’t seem to find any other explanation for the memory rise, and it only happens while bitcomet is on
here’s some info:
1.32 64 bit
ADSL 5MB
**3) **Do you have a modem? Do you use a router? What make and model are each one of them? Have you forwarded your port?
Irrelevant, ports are forwarded , no problems with connecting to my provider
4) If you have more than one router, be sure to mention the make and model of both devices, how are they connected (i.e. in which connector of both devices is the network cable plugged) and which one of the devices is connected to or is the modem.
Also, if you have more than one computer make sure to mention in this case, to which router is every one of them connected.
Irrelevant
Windowns 7 ultimate SP1, windows firewall is off, using avg internet security 2012 with bitcomet in its firewalls exceptions
6) If you are asking about a specific torrent or file that you have downloaded, make sure that you include the complete torrent name, as well as the complete names of the files and their respective extensions/formats (e.g.: .rar, .wma, .bin, .cue, etc.).
Irrelevant
7) For speed-related issues, please run various speed tests at a site such as speedtest.net (make sure that no other computer is using your Internet connection and that all other programs - including BitComet - are closed, during the tests). Include the results, along with the settings that you are presently using, in your post, so that we may review and offer suggestions to improve its performance.
Irrelevant
thanks for your time
